*** Urgent Help needed - Thermal paste on CPU pins!!
sitheris
I was cleaning my processor (A64 winnie) because I"m installing a new HSF, but I put too much thermal paste on when i originally built the computer, (i used the stuff they sell at best buy, not sure what it's called). Anyway, when cleaning it, some of the paste fell down the side of the processor and onto the pins. I can't get it off using q-tip and alcohol, it's like mushed in between the pins.
Is this harmful or how can I clean it up??
Thanks
Go to your local auto parts store and get some spray on paint prep cleaner. Painters use it to prep the surface of cars before they are painted. It removes wax, oils and dirt. It will also remove the processor paste and it won't hurt plastics like acetone or carb sprays can so you don't need to worry that it will hurt your chip. I use it every time I reseat the hsf and I've had zero problems with it. It will dissolve the paste and leave everything squeeky clean and ready for a new application of the paste.
just being carful adn dabbing a qtip should work, no guarntees, and is it dynex, becuase it isint conductive, so
Just use some alcohol and soak it in there. Make sure it thoroughly dries.
thanks for the help all i got it off best i could using one of those tiny tiny flathead screwdrivers...and it still works after putting it back together so all is good now :p
Yeah, I wouldnt soak a cpu or spray it with anything. Good thinking with the screwdriver. If you got liquid inside the cpu it would have never evaporated, and would have expanded when heated... which you can imagine is not good.
Nope, wrong. If liquid can get IN, it WILL evaporate since the vapor can escape through even smaller orifices than the liquid form.
Mate I had this
you know what fixed it, put some thermal paste remover on leave it on for abit then I washed it with cold water, man it worked wonders and got rid of all of it, I then just left if for about 10 mins and walla worked perfectly.
