current setup:
core 2 duo 6600 2.40 ghz
2 gigs of ram
Geforce 7900 GS
Samsung 2253 BW 1680x1050 widescreen
Asus motherboard that supports SLI (only single card right now)
Windows XP Pro SP 3
DirectX 9.1
Right now, I can run Oblivion in Medium/High at 1680x1050 and pull around 40-60 fps. I have a lot of things disabled and doesn't look as good as it should. The other problem is that it'll drop those fps (once in a while) to around 10-30 in some areas or during combat (which is kind of annoy).
With my current setup and a few upgrades, I'd like to run 1680x1050 with "high" settings and pull in a decent FPS constantly, not just in some areas.
What would be the most 'bang for my buck'? Going to a Geforce 9800 GT? Throwing another 7900 GS in there (for SLI)? Maybe an ATI card?
I could go to a higher CPU - but doubt that would gain me much?
2 gigs of ram
Geforce 7900 GS
Windows XP Pro SP 3
DirectX 9.1
