Upgrading tomorrow - $500 limit
mokkapoop
Ok guys. I have had it with a slower system. I currently have the following specs:
Dell Optiplex GX260
P4 2.4GHZ 512KB 533mhz
1gb pc2100
Geforce FX5200 128MB (YEA I KNOW)
500GB hd space
16x Pioneer Dual Layer DVD-RW
Gateway FPD1960 19" 8MS LCD (GREAT LCD)
Basically the only thing I am going to carry over is the LCD and HD. Now, I will be going to Fry's tomorrow. I most likely will be purchasing a cpu + mobo combo (core 2 duo), 2gb ddr ram, PCI-E video card and a new case.
Now, we mostly will use the pc for email, internet, downloading (10mpbs download / 1mbps upload), watching DVD's (which the current specs suck at it), ripping dvd's, and possibly getting back into gaming (BF2). I will also get back into creating websites, photo editing, and video editing.
Now, do I need to get a Core 2 Duo system? I don't plan to go to Vista for at least a year. What do you guys suggest I do in this situation? Any suggestions on specs?
Save the money for a while, $500 won't get you ram/cpu (c2d) & mobo/case/video..Nothing that will run BF2 @ "high" res comfortably... Nor a case worth buying IMO, best you could do is one of those piles that they give with their BYO systems. And what about the PSU? I'd bet it's likely you'd need to upgrade that as well. I'd reckon you need to allocate another $300-500 at least to get all you wanted, and not have crap parts.
And yes, IMO you should get a C2D, while not required for BF2, it will make video & photo editing a nice bit faster - it's worth it. And if you plan on getting any games coming out this year, you'll want dual core - the A level stuff will likely be receptive to a dual core system.
e6300 = 180, ds3 = 125, gskill 2gb ram or comparable = 170, centurion 5 = 50, evga 7900gs ko =150 AR
Total = 675
Thats what I ended up with. If you need a psu then add another 50 (xclio is good).
You could save on the processor and get the 4300. You could buy a cheap vid card for now like the 7600gt and spend more later when you have more using evga's 90 day stepup program. Definitely get 2GB of ram. You could definitely save on the case by buying used or one of those wizard cases which are free after rebate. Whats wrong with the old case?
I would save up another 200-300 myself and then buy. Maybe you could sell your old parts here?
get a 7600 GT better value for your money...
as for the cpu unless its a big diffrence from the 4300 get the 6300 (if the prices are less than 10-20 $ diffrence... otherwise the 4300 is a better buy
Those specs are far more than enough for email, internet, downloading, and watching dvds. Ripping dvds would of course be faster with a faster cpu and gaming could benefit from some upgrades, but ripping is an overnight process anyway so who cares, and if you aren't actually gaming, but merely possibly planning on it, there is no reason to upgrade.
you wont get much with just 500 dollars. Like other ppl have said save up 200-300 dollars more and then upgrade
Buddy just upgraded his son's computer. He wanted to go cheap but fast and stable, here's the parts list. You can use some parts from your old system as well (like the ram)
e4300 = 169
ASRock 4CoreDual-VSTA = 60 (or 775dual-vsta)
SAPPHIRE 100199L Radeon X1950GT = 125 (after $25 rebate)
XClio 450BL ATX 450W Power Supply - Retail = 47
$401 + some case fans and a fan for the north bridge
Use your current RAM/HDD
easy overclock to 2.4ghz, 2.8 doable, 3.0+ unlikely
Open box video card - 119
Open box mobo - 34
wait for the price drop in a few weeks for the cpu and get cpu = 119 (ish) or 4400 = 138 (ish)
Ripping an overnight process? It takes me 20 minutes to rip a dvd9.... It could be due to the proc (CoreDuo), but I'm sure it's because of the drive (Nec 16x dvd).
Total = 675
or get the PNY 2 gb of ddr2-667 set for 92 dollars(look in hot deals)
Wait a bit. Aren't prices for c2d dropping in april? You can easily wait a month and work with your current computer and then by april may you should be able to get everything very close to 500 if the price cuts are good and you go with the 90$ PNY ram listed above. You may also have more saved in a month and be able to pick up some extra goodies too.
wait a bit, c2d prices are gonna drop real soon, plus maybe by then you may have more money to spend on an upgrade.
Also, do I really need to go Dual core anything (Intel or AMD) if I dont plan to upgrade for quite some time?
Wait till April 22nd. Thats when the price drops are suppose to happen. And it's a always a good idea to go with a dual-core processor because it's really useful for multitasking.
Yes, wait for the E4300 to be $113, and build a Core2Duo system at the end of April.
Couldnt I build a system that can take core 2 duo chips, get something like a good p4 for now, and upgrade to that when the time comes?
I bought my system because my motherboard died and it was also time so I did everything at once and splurged. You can always play the waiting game with technology and keep waiting. If you want something new right now, just go spend the money. Who cares as long as you are happy. Since everything is working and april 22nd not that far away..., wait. I was using an athalon 1GHz so I know what slow is and can empathize.
if the e4300 becomes 113 + 92$ ram + 100$ mobo (I know there is a biostar one around this price that is good) + centurion 5 case for 50$ +xclio goodpower psu for 40$ + 7900gs ko for 145$ would work well for you. Total end up being 540. You just have to save 40 more dollars.
yes, you could build an upgradable system now... but why? If you can wait, then do so. If you can't, then instead of a C2D CPU, you'll buy a Celeron? for $50? then when the C2D prices drop, you'll lay down another $113? So you're willing to pay $163 for the CPU? just buy it now if you want to spend that much, hehe. Go with blendingnoise's build, but get the Centurion case from svc.com:
$163 - Intel Core 2 Duo E4300 Allendale 1.8GHz 2MB L2 Cache
$105 - Biostar TForce965PT LGA 775 Intel P965 Express
$67 - Patriot Signature 1GB (2x512MB) DDR2-667 PSD21G667K
$38 - XClio 450BL ATX 450W
$30 - Cooler Master Centurion 534 RC-534-KWN1 Black Steel ATX Mid Tower w/ Side Window
$405 + tax and shipping...
Spend whatever is left on a video card. Here's an egghunt of the 7600GTs... there are some for $90 AR: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Description=7600gt&x=0&y=0
You'll be slightly over budget if you build now, but if you wait, I think you'll be closer to your budget mark. If you want to build now and want a cheaper board, you can go for a 945 chipset instead, but you'll have limited overclockability as well as limited upgrade ability.
