Upgrading the wife's compy...
Dalemite
Looking for some build advice for upgading my wifes aging computer. It is currently running a C2D E6750 CPU and an 8800GTS video card. Some of the games she plays is making this thing show it's age. On to the questions:
Most strenuous thing will be gaming. Things like Diablo 3, CIV5 and MMOs.
Overall budget in the $400 range, $350 if possible.
Milwaukee, WI area. No Microcenter yet.
We'll need a mobo (must be mATX), CPU and RAM. Also need a 1-2 TB HD for her iTunes and files and maybe a SSD if we can fit it in the budget.
Reusing a Corsair 520W PS, case, getting a GTX460 out of my computer. Also could re-use the WD Blue 640GB HD if we can't fit the SSD into the budget.
6) Will you be overclocking?
No overclocking.
22" 1080 monitor.
With a couple weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Nothing special needed.
Win7 64bit
Thanks to all in advance.
I would look at something like this from tigerdirect.com
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=8869088&CatId=7722
Its an AMD A10-7850k processor, 8 gigs of memory and an Asus motherboard. It may not be as fast as some of the Intel offerings but it should win out on price vs performance. More importantly I think the graphics that are built into the chip will outperform the video card you were planning on using.Add in that you still have the ability to put a better video card in it if you want.
