Upgrading system - Feedback appreciated
wubism
Gaming. Currently play CS:GO and Overwatch. Not to demanding but want the capability to play more demanding games at a good quality. System also hosts a Plex Media Server.
Up to $650 including Tax/Shipping.
Lenexa, KS. Very close a Micro Center.
SSD, GPU, RAM.
CPU, MOBO, CASE, PSU, Secondary HDD.
6) Will you be overclocking?
No.
1080p 24"
By 4/1/16 at the very latest.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Not upgrading current motherboard unless convinced to do so.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, Windows 10 64bit.
Current setup:
i5 2500k Sandy Bridge
ASUS P8P67 Pro
8GB (2x4gb) G.SKILL Value Series DDR3 1333
EVGA Nvidia GTX 590 Classified
SAMSUNG Spinpoint F3 ST1000DM005/HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s
CORSAIR TX Series CMPSU-750TX 750W ATX12V v2.3
COOLER MASTER RC-692-KKN2 CM690 II Black Steel
Upgrades I am currently considering
G.SKILL Ripjaws X Series 16GB (2 x 8GB) DDR3 1600 $71.99
- G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9D-16GXM - Newegg.com
SAMSUNG 850 PRO 256GB SSD $139.99
- SAMSUNG 850 PRO 2.5" 256GB SATA III 3-D Vertical Internal Solid State Drive (SSD) MZ-7KE256BW - Newegg.com
EVGA GeForce GTX 970 $309.99
- EVGA GeForce GTX 970 04G-P4-3975-KR 4GB SSC GAMING w/ACX 2.0+, Whisper Silent Cooling Graphics Card - Newegg.com
Total: $521.97
Any help/feedback/suggestions would be greatly appreciated.
The only thing I would really recommend changing is the SSD: I recommend getting the Samsung 850 Evo 512GB instead.
Thanks. Is the Videocard I linked a good choice for a 970? I've always had good luck with EVGA.
Seems like great upgrade choices. I know you don't want to overclock, but you should reconsider it, you could bump that 2500k a bit higher and enjoy more fluid gameplay.
