Hi
Current build: links below
cpu: AMD X3 720BE
mobo: Gigabyte MA790XT-UD4P
graphics card: XFX Radeon HD4870 (1gb GDDR5)
memory: kingston valueram - 4GB DDR3 @ 1333mhz
os: windows 7 32bit
Use:
General use (mailing, streaming movies, browsing,...)
Intense use: I will be playing SWTOR when it comes out (late 2011) and want to be sure to have a rig that can handle everything on maximum settings at a resolution of 1920x1200. Requirements are not yet known.
Questions:
1. The Gigabyte website shows that my motherboard can handle the newer 6 core cpu's but will my almost 3 year old motherboard be a bottleneck for this processor?
2. Upgrading to a newer graphics card or putting another 4870 in for crossfire?
3. Use a SSD to put the OS and frequently used applications on? Which brand?
4. Keep the processor, overclock it and try to unlock the 4th core?
Links:
Motherboard information (CPU support on the right side)
CPU information
/edit: Budget is around 400 euros
Any help/insight is appreciated!
Greetings
cpu: AMD X3 720BE
os: windows 7 32bit
Use:
Questions:
Links:
CPU information
Greetings
