you've never heard of anandtech? and your a 4 year vet of hard forums? what?!
The 8800GT sli is above both the GTX280 and 260 in all benchmarks listed in the link. Any game that does not take advantage of SLi doesn't really need the performance boost anyway. My 8800GT blows away any game released before 08.
I never really believed overclocking could have a noticeable difference, i have tried overclocking both my CPU, got it up to 3(unstable, CS:S crashes, plus im using stock heatsink) and GPU(no difference in crysis, and it got hotter), and it doesn't seem worth it.
If i do get those upgrades, then it would be cheaper than the best single-gpu solution out right now.
At a 24" monitor, the 8800 SLI will not be enough for good amount of eye candy. At least, not anymore.
As for overclocking, you clearly didn't overclock properly.It's easily worth it.OC'd E4500 = E8400? How is that not worth it?
No way does sli 8880gt beat the 280, maybe 260.
Even if i were to overclock the e4500 to 8400 speeds, the 8400's cache would still beat the 4500's, and if i were to overclock the 8400 the same amount i did the e4500, then the 8400 would be significantly faster. .
Yeah, but with the GTX260 route you could probably sell your 8800GT for around $80 - $90. You may be able to run it on your current PSU also, which puts you way ahead price wise.no, sorry i forgot to include my motherboard. (msi neo combo)
according to the benchmarks sli 8800gt's blow a gtx260 away. another 8800GT is roughly $100, add a $160 sli motherboard, and it is still cheaper than the gtx260 while performing better.
am i right?
Lol? The 8800GT SLi beats the GTX280 and 260, what do you want me to do, sli the 280? I am 16 without a job... Im not even sure im going for the 24''
Saying the monitor is unrelated is like saying the ripeness of the avacado is unrelated when making guacamole.
I know i will be going for at least a 22'' monitor, might be going up to a 32'', as i said i dont know.
tiraides, i am thinking of just upgrading the gpu/cooler right now, maybe ram. anyone have any thoughts on RAM? Would i notice a difference if i upgraded to 4GB and x64 windows? My mobo only supports 2 slots of ddr2/ddr3 so i would have to buy 2 new sticks.
I'll make it easy on you:
$50 - G.Skill 2x2GB DDR2 800 kit (free shipping)
... and your choice between...
$32 - Arctic Cooling Freezer 7 Pro (free shipping) & LGA 775 bolt-thru kit -or-
$33 - Xigmatek HDT-S964 ($10 mail-in rebate) & ACK-I7751 retention bracket
Based on the Hardware Secrets review, your board supports both DDR2 and DDR3 RAM (though not both at the same time). However, it's pointless to go with either DDR3 RAM or RAM faster than DDR2 800 speeds, even for overclocking (especially with the processor you have). The Freezer 7 Pro and the HDT-S964 essentially perform around the same (read: better than the Zalmans I mentioned earlier), so choose whichever one gives you the most "benefit."
