Ok, I'm doing an overhaul to my gaming PC. In some of my parts ill put a link so u can see them.
First a list of the parts I already have and I'm planning to keep on the new build:
-PSU: Antec NeoPower 650 Blue 650W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371010
-Video Card: VistionTek Radeon HD4850 512mb DDR3 PCI-E 2.0
-Audio Card: Audigy 2 ZS
-DVD: DVD+-RW (x2) SATA
This are parts I'm not going to change right now, but probably withing a month or 2.
-HD: 250GB Sata2 (Backup HD)
Will Raplce with
-Western Digital Caviar SE16 WD6400AAKS 640GB (Backup HD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
-RAM: 4GB (1GBx4) CORSAIR XMS2 DDR2 800
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145034
will replace with either: (Which would be best???)
-CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
or
-CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145197
Stuff I need to change Now:
-CPU: C2D E4400
Will Replace with
-C2D E8400
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
-HD: 200GB Sata1 (OS Drive)
Will replace with
-MoBo: GIGABYTE GA-965P-DS3
http://www.newegg.com/product/product.aspx?Item=N82E16813128012
Replace with
Ok, for the mobo, I think I might just go with 1 PCI-E x16, I don't know if Xfire is really worth it for me, since I usually just end up selling the old video card and getting a more powerful one.
I would like to have at least 6 USB on the back of the Mobo.
I don't know how important is E-Sata on the back of the mobo?
Will Raplce with
or
-CPU: C2D E4400
Will Replace with
-C2D E8400
Will replace with
Replace with
