1) What will you be doing with this PC? Gaming? Photoshop? Web browsing?
DVR Security System
550, Yes.
Los Angeles, CA
CPU, RAM, CASE, Hard Drive, Power Supply
Thermaltake Purepower 430 NP ( I'm not sure if this will still work with the new parts I'm getting.)
6) Will you be overclocking?
Nope
1680x1050
I plan on buying parts today or tomorrow
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0, Sata 6Gb/s.
Windows 7 64Bit.
I currently have a few things in my cart right now.
I was thinking get an i5-2500k. processor just in caseI end up getting PTZ, or IP Cameras down the road that this PC can handle it. My current Security System PC has lasted me around 7 years now is noticeably slow.
If any of you think i should be getting other things please i am open for suggestions! As far as the hard drive goes. I was told to get an av-gp drive because they are designed for constant read/writing.
Thanks!
DVR Security System
550, Yes.
Los Angeles, CA
Nope
1680x1050
Windows 7 64Bit.
Thanks!
