I'm looking to get a new video card, add a second HDD, and pick an appropriate PSU to run the system. So far I've picked:
PSU: CORSAIR CMPSU-750TX 750W
HDD: SAMSUNG Spinpoint F1 HD103UJ 1TB 7200 RPM 32MB
GPU: EVGA 896-P3-1255-AR GeForce GTX 260
I'd like to partition the new HDD four ways to use it for storage, win xp, hackintosh, and possibly linux. I'd like to spend as little as possible on the PSU, but this seems to be a solid choice sufficient for everything. It will replace a 300W PSU that came with the system (I think the new one should fit because they are both standard size?)
Finally, the video card: I set my mind to a GTX 260, but I'm a little concerned about its size. I've considered this 4870 as an alternative - but it's not that much shorter. So I did a little measuring and here's what I have:
The orange line - bottom - is the current vid card, with top orange bar shown to match a picture of a comparable 8500 GT. They're fairly short. Now if you look at the blue card behind it, that's the 4870, just a little shorter than the third card - black - that is a GTX 260, which I've read is ~10.5in.
I have 11.5 in until the case becomes problematic. However, there are wires for SATA that both the ATI and Nvidia cards seem to imminently run into (green dots) - but there are 6 SATA slots, and only 3 are currently in use (0-2). Can I simply switch them to the bottom ones, 3-5, to avoid being in the way of the card if it's an issue?
I'd like to hear some thoughts on my choices for the upgrade? Do you think card size will be an issue - meaning the components on the motherboard sticking up too high? If I go with the GTX 260, would the 'Superclocked' cards be in too tight a space - I only have an exhaust case fan on the HP case?
