Mostly Adobe Premier, Encoding, Photoshop, Gaming and such
Willing to spend somewhere between 600-800, looking for price/performance
3) Where do you live?
NJ
Case, CPU, Motherboard, RAM, GPU
PC P&C 750w PSU, optical and hard disk drives, all peripherals
6) Will you be overclocking?
Negative
22" 1620x1050, plan to eventually upgrade to at least 24" 1080p (not right now though)
Within the week unless there's something worth waiting a couple weeks for
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
No preference, just a decent amount of USB
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
64-bit vista, will upgrade later
The system is mainly used for video editing. My current E8400 is really feeling its age. Looking to boost Premier performance and switch to NVidia graphics (currently using an HD 4870 512MB, I head NV works better for Premier). I appreciate any suggestions
NJ
Negative
