Upgrading for around 400 bucks
Rydawg5143
SO i sold my 2nd unused pc. I want to take that money and upgrade my main system.
WHat i have is an AMD Athlon 64 x2 4000+, Generic mobo came with computer, BFG8800GT 512 MB OC, 2GB G.Skill (2x1), Corsair 450VX.
I'd like to upgrade my mobo and cpu and grab another 2gb of G.skill.
I have always had good time with AMD, and prefer to stary with them. Don't want to upgrade my GPU or PSU atm as I think they are pretty good. I use this computer for gaming and trolling the net. TF2, Everquest and soon will be playing a couple Others. I dont play on any huge Monitor, just a simple Acer 19' WS.
I dont need a quadcore or tri. So thinking of a AMD Athlon 64 x2 6000+. WHat would be a good Mobo for this CPU
- So subtract $45 for 2GB of G.Skill RAM and you have about $355 for the mobo and CPU correct?
- What features do you need in a motherboard? RAID? Firewire?
- Will you be overclocking?
Are you sure you want to stick with AMD? I mean you do have enough money for a decent Intel build that'll outperform most AMD setups.
I've had 2-3 intel systems, not including the ones at work. Have never been too happy with them. Then again these were mostly years ago. So i dunno :/
I have never overclocked, would like to try soem day in the future on my gf's comp :p before mine
No RAID, i read all about it last couple days and still have no idea what it is besides soemthign about multi HD's ?? :(
Good primer on RAID:
http://www.bit-tech.net/hardware/2007/06/11/understanding_raid/1
Intel systems are pretty stable these days. Actually pretty stable a few years ago.
1) Well if you're willing to OC right off the bat and want to go with Intel, I recommend this setup:
Intel Pentium Dual Core E2180 CPU - $60
Gigabyte GA-EP35-DS3L Intel P35 Motherboard - $90
Xigmatek HDT-S963 92mm Rifle HSF - $25
Total: $175 plus tax and shipping
2) If you don't plan on OCing and want to stick with AMD, I recommend this setup:
AMD Athlon64 X2 6000+ CPU - $153
Abit AX78 AMD 770 Motherboard - $95
Total: $248 Plus tax and shipping.
3) If you don't plan on OCing but want go with Intel, I recommend this setup:
Intel Core 2 Duo E8400 CPU - $195
Total: $285 plus tax and shipping
4) If you plan on OCing' later on and want to go with Intel, I recommend this setup:
Intel Core 2 Duo E7200 CPU - $132
Total: $247 Plus tax and shipping.
Just so you know, Build #1 (when OC'd) #3, and #4 will outperform Build #2 without a sweat.
After reading these forums for awhile, I've only read Good things about option 3, SHould i get the Xigmatek HSF for it as well?
ALso i forgot to add, Would there be any issue of all 3 of these going into a Mid-tower Acer case? I wouldn't think so but suppose if I get em and soemthign don't fit, then i GUESS i'll HAVE to buy a new case /cough Such a tragedy
Go for it if you have the money to burn or plan on OCing a little later on. Though if you want to reach the highest OC possible with the E8400, I recommend getting the bigger version of that Xigmatek HSF:
Xigmatek HDT-S1283 120mm Rifle HSF - $37
Since you want AMD, I vote for build 2. If you decide to go to the dark side, I vote for build 4.
EDIT: Jeez, I'm slow when I'm sick... If you get the Xigmatek, I recommend getting this, too:
Thermalright LGA775 Bolt-Thru-Kit
Is the E8400 worth the 60 bucks difference compared to the E7200? Both these paired with the GA Mobo will rock what i currently have, but is it worth it for 60 bucks?
Having never OC'd before. Wouldnt putting something past what its original design was for decrease the life of said item
Going with the E8400 after all, also added a 36gb raptor, sounds like its the way to go for putting your OS on?
Nope, Raptors are no longer worth their price premium. If you want a fast HDD, go for a Samsung F1 series or a WD3200AAKS or WD6400AAKS instead. Or, if you can wait, the new VelociRaptor should be out soon. Any of those drives would be faster than the 36GB raptor.
If overclocking decreasees the life span of CPUs, then CPUs have LOOOOONG lifespans. I've been running my AMD overclocked for the past 6 years. I'm just now building a new system.
I went with the E7200. Saved the $60, and a mild overclock would put me back inline with the more expensive chip. These chips seem to handle the o/c pretty easily, too.
I was a hardcore AMD guy, but I just found the price/performance bargain of the Intel chips currently to be the way to go. Option #4 listed down there is a great deal. I would get that larger 120mm version heatsink, though... no reason not to. Better temps and lower noise = a good bargain for $12 upgrade.
Either way, you can end up staying below that $400 mark including tax and shipping, I bet, and be end up REAL happy.
PS:
E2180 (dual) 2.0ghz = $70 (average overclocks to 3.0 to 3.5ghz)
E7200 (dual) 2.53ghz = $135 (average overclocks to 3.5ghz)
E8400 (dual) 3.0ghz = $195 (average overclocks to 3.75ghz)
Q6600 (quad) 2.4ghz = $215 (don't know)
Just to help confuse you. :)
Well. My $400 'upgrade' turned into a 800 dollar or so, new computer :)
Western Digital Caviar SE16 WD3200AAKS 320GB (70)
GIGABYTE GA-EP35-DS3L LGA 775 Intel P35 ATX (90)
Logitech MX518 (40)
XIGMATEK HDT-S963 (25)
Logitech 980186-0403 Silver USB Connector USB Desktop Microphone (20)
Intel Core 2 Duo E8400 Wolfdale (196)
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 800 ( 44)
Vista Home Premium (95)
Samsung DVD etc (35)
Add on my already HD3870 or 8800 GT OC and gtg.
Also Going to either buy Antect o182, 900 or the Coolmaster in hot deals atm, headed to MC after work. Just need to find a good deal on External Harddrive now
I don't want to overlock this computer but wanted the higher speed i suppose.
Well, these things are easy as cake to OC, so once you notice your system isn't as fast as it should be, grow a pair and read up on OC'ing. :p The E8400 could reach upwards of 4Ghz, btw, with proper air cooling.
Yeah i kind of got to the point of like, well... if i'm going to do it, may as well do it all!!
