My PC had been getting BSODs on a regular basis for a while. Resetting the mobo tends to fix the issue, but once I shut down the PC the problem returns on the next boot.
I've come to the point where I just want to upgrade. Go from the AMD 555BE (4 core unlocked) to something intel based.
Gaming mostly with DVD rips, photoshop, etc mixed in. But primarily gaming first
$250-$350 for upgrading the mobo, cpu and ram
US
CPU, Ram, Mobo
HX620W Corsair
GTX 480
Case and other random parts, dvd burner, HDDs, etc
6) Will you be overclocking?
most likely not
7) 7) What is the max resolution of your monitor? What size is it?
1920x1080
0-3 months
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
The basics, no onboard video, doubt I'd bee crossfire or SLI
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Win 7 64bt
Basically what I want is an upgrade over the 555BE, which I assume should be easy. Double the ram and of course I'd have to get a new mobo. For the CPU I just want something that wont ever bottleneck me if I upgrade my video card in the future. I've had a bit of bottleneck in a few games since my 555BE doesn't overclock very well at all.
I'd also consider a small SSD for my OS and the few games I'd want on it, but I have yet to consider this and the research I've done so far has only confused me more about SSDs. Prices, speeds, reliability, etc Is there a good low end SSD that users on [H] like?
Anyways, for the upgrade I am wondering if I should wait a bit as the new intel chips are coming, or go for something more powerful than the 2500k. That cpu has always seemed like what people base their build around for an affordable gaming PC, so I chose that.Honestly I've been out of the market for a while and it'l take some more research from me to get back into the scene.
I can buy parts from anywhere, Microcenter, Newegg, Amazon (preferable since I hav some credit there)
US
CPU, Ram, Mobo
HX620W Corsair
GTX 480
most likely not
1920x1080
0-3 months
Win 7 64bt
