Ive got a comp thats about 3 1/2 years old (it just hit me today how long its been)
and im looking to eeek a little more juice out of it before I go for a new system build in the next 6-8 months. Ive orderd a new display (22" Samsung ftw), and obviously my system is woefully underequipped to take advantage of it (but it will look pretty on my desk damnit).
My system as it stands today is
Radeon 9800 pro 128mb
Amd Athlon 2600+ (~2.1 ghz...so stock speed really)
A7N8X Deluxe mobo (socket A according to asus website, http://usa.asus.com/products1.aspx?l1=3&l2=0&l3=0&modelmenu=0&share=txt/60)
1 gb RAM (two decent 256's and a crappy 512, but dual channel is running properly)
now ive got a decent heatsink and artic silver stuff, so the CPU runs cool (38 C... without the artic silver) and there is some room for OCing (if im not mistaken). Ive had some problems with OCing through the bios, is there any easier way to go about it? Can my vid card be OC'd and how would I go about doing that (omega drivers have a utility, but i dont want to mess with things I dont understand).
Beyond OCIng the obvious thing to do would be to get slight cheap upgrades to tide me over. Am I right in assuming the processor upgrade path is closed to me, as my mobo wont run even the old Sempron chips? (http://www.newegg.com/Product/Produ...0001028+1051707438&Submit=ENE&SubCategory=343)
is it worth it to even try to upgrade to the 3200+ (if I can find somewhere that sells socket A, barton?, chips)
Is a GPU upgrade worth it?
RAM?
im trying to keep any stopgap upgrades cheap, as ide like to build a new system in the forseeable future, however ide also like to have a performance boost that can get me through the intervening months and perhaps allow me to put off the rebuild for a little longer.
In addition I have no idea what kind of system I should be looking to build in 6-8 months, ide like to keep costs to less then 800 (I know its hard to follow price guidlines 6 months in the future) so any tips/advice you would like to offer would be much appreciated.
sorry for my ignorance, a baby and life in general have kept me out of the loop for the past years.
thanks
any help is greatly appreciated
RAM?
thanks
