Upgrading a friend.
OmegaSpade79
Hey,
A friend of mine is using this motherboard
Acorp
It currently has a celeron 1.8 and 512 2100 RAM and a GF2 Ti.
He wants to upgrade so he can do some gaming.
I am suggesting a 2.8GHZ P4 533FSB (Is there a hyper-threading version at 2.8 533?). Or is the $43 price difference to get the 3.06 533 w/Hyper Threading worth the money?
Additionally an Ati 9800 Pro 128.
I do not think he would see that great a difference in speed between 2100 and 2700 ram so unless he decides he NEEDS to go to a gig I don't see a pressing need to replace the RAM.
My emphasis for choosing the parts was best value for price.
Your thoughts?
If hes got the cash, replace the motherboard and go with:
Abit IS7
P4 2.8C 800fsb
9800 Pro
PC3200 RAM
If not, merely upgrading the video will improve his gaming performace tremendously.
If I tell him to replace the motherboard, I might as well build a whole new system. He doesn't want to drop that kind of money. Plus, that motherboard and ram would add around $240 to the cost which is almost a 50% increase in cost and I highly doubt it would result in a 50% increase or great performance increase. At least that is my justifacation for not changing the motherboard.
You can upgrade the CPU for now and upgrade the motherboard later. But keep in mind that you'll need to stick with a 533MHz FSB CPU or you'll have to underclock an 800MHz FSB CPU or you'll have to hope his motherboard is a good overclocker, which I doubt. But yeah, I would recommend upgrading the motherboard and RAM soon too....
