Upgrading 970, help appreciated.
Looking for best value for the money. Right now I am considering:
New 1660TI
Used 1070Ti
Used 1080
Budget ~$300
What do guys think would be the best?
kirbyrj
[H]ard as it Gets
Best value is a used 1080 if you can buy it right (harder to do recently). Another alternative is a 1660Ti from EVGA B-stock which is around $230 shipped with 12 month warranty. 1070Ti is around $230-260 and is 95% of a 1080.
The best bang for the buck though at $300 is a vanilla Radeon 5700 flashed to the XT.
Jandor
I wouldn't buy a used graphics card because gaming graphics cards have their GPU and most of the tim VRam overclocked by the manufacturer. they are already on most of their limit of use. And after that many people still overclock them over the safe limit. And they may sell them when they may start to show some stability problems. If you personnaly know the guy and you're confident, you can buy his used graphics card. 1660Ti is quite close, and brand new is better. Whatever you buy now, you'll need to buy again in about 6 months to keep up with what's coming (which will be huge improvement) and will become the new standard in gaming.
defaultluser
[H]ardForum Junkie
If you insist on staying Nvidia, the value of the 1660 Super is hard to beat at $230 (it's basically a 1660 ti)
https://www.amazon.com/ASUS-Overclocked-Dual-Fan-Graphics-TUF-GTX1660-O6G-Gaming/dp/B081SPGMBD?th=1
Your 970 is slightly slower than the rx 570, so it would be about 75% faster.
The RX 5700 is hard to beat, but means dropping $300 new.
https://www.microcenter.com/product/609054/xfx-radeon-rx-5700-single-fan-8gb-gddr6-pcie-video-card
I would avoid going with Pascal, as new games are starting to be aimed at Turing/Navi. The performance differences will only get more common as new punishing games are released.
Mode13
My vote is to massively cheap out, buy a used 980Ti for roughly $130-140 via forums, overclock it to 1400mhz or even 1500 depending on model, enjoy performance comparable to 1070 Ti, then upgrade again to maybe a 1080Ti or better later this year or next year when big navi and rtx 3000 are around.
I'm biased of course since that's how I played it... I don't think 1080s are going to be worth the $300 or so people are asking in short order once sales start hitting the rx 5700 ...and then rtx 3000 shows its face... Probably won't lose too much on the resale of the already cheap 980Ti when swapping it back in later.
[ymmv with power consumption, and the 6gb frame buffer is still totally adequate for 1080P/1440p in my experience...]
Westwood Arrakis
I went from a 970 to a 1060 6gb and its been flawless. Paid like $150 for it from someone here.
Ricky T
That is not even a decent upgrade as the performance difference is under 20%. And the 970 was a better overclocker so comparing overclocked to overclocked it's like a little over 10% difference. The only real advantage of course is the extra vram.
Westwood Arrakis
Hrm. Then perhaps I'm mistaken. I thought it was a 970...
cyclone3d
[H]ardForum Junkie
Finance a 2080ti for 4 months ($300/month). This is the way.
LOL
What resolution is the OP going to be playing at? If only 1080p.. or even 1440p, then a 2080Ti is kinda overkill.
I upgraded to a 2080 from a 1080 and only game at 1080p at the moment. (Bought a 1080Ti that was still under warranty and it ended up being faulty and EVGA sent me a 2080 as a replacement).
Everything I have run on it thus far maintains 75fps (max my freesync monitor goes) with no more than about 25% GPU usage with settings maxed out. I watch the GPU usage on my second screen. I am overclocking the 2080 with +100 for the GPU and +700 for the RAM which is what a lot of the different reviews said was the normal overclock they were seeing.
I haven't tried to push it any further.
Games I have been playing:
Destiny 2
The Division 2
Warframe
Granted, there are more demanding games out there but I still find it hilarious at how low the GPU usage is.
kdh
I went from a 970, to a 1660ti. Was a monster upgrade for me. My 970 was a great card and lived in a bunch of machines, and I definitely got my moneys worth out of it. Feel the 1660TI will be in the same boat and will easily last as long as my 970 lasted me. I use it more then my 1080, and 1080ti.
DejaWiz
Oracle of Unfortunate Truths
Budget of $300 for nVidia...go with a 1070Ti, 1080, or 2060 for used; 1660Ti/Super for new.
Reactions: xx0xx
Ricky T
LOL
Destiny 2
The Division 2
Warframe
There is zero chance you are only at 25% gpu usage on max settings 75 fps at 1080p in a game like Division 2.
cyclone3d
[H]ardForum Junkie
I'll test again tonight but I'm pretty sure that that is what I was seeing according to the load monitoring (not power monitoring) in EVGA X1.
Ricky T
If you are only seeing 25% GPU usage then it's absolutely being reported wrong. That would mean a 2080 super is capable of 300 FPS in division 2 which is not even remotely possible. Plus when GPU usage is that low then clock speed is usually even below base clocks which will mean that would be even more headroom meaning the GPU was really only at about 1/6 its actual capabilities which again is beyond possible.
cyclone3d
[H]ardForum Junkie
So testing again, if I am running around and even in fights, the GPU usage that Windows is showing is less than 20%. If I zoom in with my scope, it jumps up to 28-50% usage for a couple seconds and then settles back down to less than 10% when not in a battle. Around 10% when in a battle.
Going to test with vsync disabled to see what happens.
Maybe Windows is reporting it wrong.
Edit... Well, turning vsync off jumped the fps to around 115-200 depending on where I am looking (outside and in fights).
I am completely CPU limited when doing that though as my CPU usage jumps up from around 45%+ to 85-100%.
GPU usage is being reported at around 18% when doing this. Turbo settles at 2010 for the GPU clocks with it warming up to a whopping 67C. Both fans bump up to 85% speed per my custom fan curve... maybe I should raise them to 100%. Maybe it would boost a bit more.. but I don't play with vsync disabled so what is the point?
Edit 2 : With MSI Afterburner, the GPU usage being reported is way higher.. up to around 97%. If that is really the case, then what in the world is Windows 10 GPU monitor reporting?
Or is MSI Afterburner reporting the percentage of the Power Limit % setting?
Ricky T
Windows GPU usage is all jacked up. In afterburner I am seeing around 60 to 70% average GPU usage at 1080p maxed 75 FPS with my 2080 super.
AIM9x
[H]Lite
Radeon 5700 non-XTs occasionally dip down to $300. I have a 970 as well and just put in my order last week at $300. It was backordered, but I should be seeing it fairly soon.
DooKey
[H]ardForum Junkie
I finance my GPU purchases all the time. Can't beat PayPal six month no interest. Why should I pay out all the money at once? I love using other people's free money! I always use free money if it's offered.
Furious_Styles
Yeah I got the newegg store card and they will offer 12month no interest on stuff. If you are buying an expensive card it's sorta like why not?
Borgschulze
I went from a 4690K 4.5ghz and a 970, to a 1660 Super, very good upgrade, very happy.
That jump was massive, going from the 4690K 4.5ghz to a Ryzen 5 3600X made very little difference in gaming.
kdh
Thanks for all the recommendations everyone. I was able to pick up a very lightly used 1080 for $250, hopefully I notice a big upgrade :D
That's a hell of an upgrade. I picked up my 1080 when I got my vive and it did VR things really well with it for about 2 years. From a 970 to a 1080? Thats a sweet jump. you'll be very happy with that for atleast another 2 or 3 years.
