Upgrades: Take 2
Razer X
I had started one of these a month ago when I first put in an order for a LG 34UM95 and the advice that was given was to wait. It turned out to be good advice as I ended up deciding to scrap a couple of other projects and can now put those funds to upgrading my PC. I am scheduled to get my new screen tomorrow and all the research I have done has told me I will need to upgrade to get maximum performance in games. Besides, I have the money to spend now anyway. :D
Current rig:
Intel Core i5-2500K CPU
Gigabyte GA-Z77X-UD3H Intel Z77 ATX Motherboard
Corsair CMV8GX3M2A1333C9 2 x 4GB DDR3 1333 RAM
Gigabyte GV-R795WF3-3GD HD 7950 3GB PCI-E Video Card
Corsair 650TX V2 650W PSU
NZXT Source 210 Elite Black ATX Case
Windows 7 Home Premium SP1 64bit OEM
Gaming mostly, I want to max out everything and still use AA which is why I'm thinking sli/crossfire. Movies are a close second and general use/light programming bringing up the rear.
$2,100.00 with shipping/taxes. That number is pretty solid, I can maybe stretch another $60 or so.
Cookeville, TN, USA
No MC, no Frye's and I'll pay tax for both Amazon and Newegg. I do have Amazon Prime so I'll probably buy everything from there.
Definite:
Video cards (sli/crossfire), blue ray player (for converting to digital), PSU?
Would be nice:
Case (mine is a bit cramped), ColorMunki Display, Ergotron MX Mounting Arm, second monitor (QNIX QX2710)
See above specs.
6) Will you be overclocking?
Most definitely.
34" 3440x1440, possibly with a 2560x1440 secondary to use for web/ventrillo/etc.
As soon as I figure out what I'm getting, probably either tonight or tomorrow.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
My current mobo has USB 3.0 and is SLI/Crossfire ready. I don't think I would replace it unless there were an issue with it and the video cards I get.
Yep. Win 7 64bit
From what I've read adding another 8 gigs of RAM won't help me much for gaming so I'm focusing mainly on the video cards. I would like to overclock so I'm doubting that my 650 watt power supply is going to cut it. I've been looking and I guess my question here is should I go to 1000 watt, or will 850 cut it? I suppose the answer to that might depend on which video cards I get.
Here is what I had been looking at:
XFX 1050
Seasonic X-850
I'm trying to decide between the MSI 780ti Gaming at $710 or either the XFX Double Dissipation 290x or the Asus Direct CU II 290x which are currently the same price at $550. Regardless of which card I pick I want to go ahead and get two. It seems the 780ti is hands down faster, but is it worth losing a little speed to get the extra VRAM of the 290x? Which do you think will be more useful down the road? I probably will not upgrade again for a few years so I want to make sure I've got enough juice to keep me going.
Browsing through internal blue ray players on Amazon I came across this LG for $70. It was one of the higher rated ones, but if I can get one that will suit my needs for less then I welcome the recommendation.
As for cases I really like the Thermaltake Chaser MK-1 but its price seems to fluctuate pretty wildly and right now it is rather high. Another one I like is the
Corsair Carbide Series Black 500R
which is quite a bit more affordable. I am certainly open to other case suggestions, but I will say I don't tend to like white cases or cases with doors on the front.
If there is any money left after everything else, I am considering picking up a second screen for $339, a ColorMunki for $140 or a monitor mount for $114. Really it just depends on how much the total comes out to.
Here are some configurations I was thinking about, keep in mind that TN has a 9.75% sales tax.
290x (times 2) $1207.23
LG BR $76.42
XFX Pro 1050 $208.51
Corsair Carbide Series 500R $109.74
ColorMunki $152.55
QNIX QX2710 $371.94
Total: $2126.39
780ti (times 2) $1558.43
LG BR $76.42
ColorMunki $152.55
Total: $2105.65
I am not completely dead set on the second screen, it would just be nice. If I don't get one now then I probably will sometime next year once I've saved up some spending money again. Honestly if the 780s will make a big enough difference then I don't mind giving up the monitor for now. I have played around with a few other configurations, but those are the two I am most leaning toward. Help me [H], spend my money! :p
IMO, you're better off with the 290X CFX setup since HardOCP's review showed that stock R9 290X CFX edged out GTX 780 TI slighty:
http://www.hardocp.com/article/2014...ation_edition_crossfire_review/9#.U6uEl_ldV0Z
As for the PSU, look at the next page of the above link. Assuming that you're also going to overclock your CPU to similar high levels as the test setup in that review, a solid 850W PSU is what you need at a minimum. But if you want a little bit of headroom, I'd recommend a 1000W PSU. I recommend this Seasonic 1050W PSU:
http://www.amazon.com/dp/B004ETEFTK/?tag=extension-kb-20
In regards to the case, the Chase MK-1 is a solid case to work with but not good enough to justify any more than $100 for it. The construction quality of that case is a little lower than the 500R hence my $100 price assessment. I do recommend looking at these other cases as well:
$100 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$100 - Corsair Carbide Series 500R ATX Case
$120 - Antec 1100 ATX Case
$120 - Corsair Obsidian Series 450D ATX Case
$120 - Corsair Vengeance Series C70 Arctic White ATX Case
$110 - Corsair Vengeance Series C70 Gunmetal Black ATX Case
$120 - NZXT Phantom PHAN-002OR Black Finish w/Orange Trim Full Tower ATX Case
$130 - NZXT Phantom 530 Black Full Tower ATX Case
$130 - Corsair Graphite Series 600TM ATX Case
$140 - Corsair Graphite Series 730T ATX Case
$150 - Corsair Obsidian Series 650D ATX Case
$160 - Corsair Obsidian Series 750D ATX Case
$160 - Corsair Special Edition White Graphite Series 600T ATX Case
$170 - NZXT Phantom 630 Gunmetal Full Tower ATX Case
$170 - NZXT Phantom 630 White Full Tower ATX Case
$190 - Corsair Graphite Series 760T ATX Case
$230 - Silverstone FT02B-USB3.0 ATX Case
$250 - Silverstone FT02S-W-USB3.0 ATX Case
Dangman, thanks for the response. I guess the DD R9 290x crossfire it is. :D What do you think between the Antec Eleven Hundred Black Super Mid Tower and the Corsair Carbide Series Black 500R? Is it the Antec worth the additional $20 plus not being Prime eligible? Also, could you link that Seasonic 1050 PSU again? You linked the 850 and when I searched for 1050 Amazon had a couple of different models.
Thanks for the help. :cool:
Here's the right PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151110
As for the cases, no, the Antec 1100 isn't worth it in that case.
I just placed the order. Everything has guaranteed delivery by Saturday except the blue ray player which will be here next week. I decided to hold off on the second monitor. I'll just save up and pick one up in a few months. I'm going with the XFX DD R9 290x (x2) the Corsair 500R, the Seasonic PSU and I'm picking up the ColorMunki and the monitor stand. Additionally I'm getting some AKG 712 Pros and the Schiit Modi/Vali combo. I've been planning on getting those for a while but was waiting to figure out what PC parts to order before pulling the trigger. Come this weekend I will have a nice personal gaming/theater setup. :D
Thanks again for the advice, I really appreciate it.
