Why are you people so afraid of overclocking your RAM?
I have 2x1GB (ECC) and 2x2GB (non-ECC) DDR2-800 sticks running at DDR2-936.
And they have different timing specs and are different brands as well.
Overclock the crap out of everything! Keep it stable at the same time though.
curtisfong - best not to buy high CAS RAM. Also, did you try upping your NB voltage a little. 4 sticks of RAM usually requires that you up the NB voltage a little.
Seems to work when I do it in system properties, but I still have Page File section of almost 8000MB in Task Manager. Is that normal ? How can I completely disable it ?
i got my 8gbs brandly newly installed into my system as well. i took advantage of that $15 4gb kit deal from frys and bought two. i love having 8gigs.
Not afraid, it just doesn't overclock well in my system. Not sure if you've tried to OC DDR3 or not, or more specifically the DX38BT motherboard, but I don't think either of them are near as forgiving as what you're working with. I'd love to get 3.6 Ghz out of my proc, but after all the headache I've gone through so far, it's not worth anymore time.
its going to cost me 50 to get another 4 gb... screw it... im getting it.
