bearvolticus
- Jun 27, 2004
i recently decided to upgrade my processor. i went from a pentium 2.4B to a 3.2E (just got it today). after switching the processors i switch on the computer and i get a warning message in POST that the CPU has been changed and that i need to go into BIOS and make sure everything is correct for the new processor. the first problem i encountered was as i was trying to leave BIOS. quit w/out save works fine but save and quit does not. sort of. i saves, just doesn't quit and reboot (that must be done manually).
of course then i still get the CPU warning again since i never really saved and quit BIOS. i can skip the warning by pressing f1 so that problem is more of a nuisance than anything.
i real problems are occuring now after a new install of windows (and no, i didn't reformat to fix the CMOS problem, the drives were just due). EVERY SINGLE program i tried to install caused at least 1 error. CD's kept getting cyclic redundancy errors, files off of spare hard drives crash because "so-and-so.file does not match so-and-so.cab", and whatever programs do manage to install promptly crash after startup (like zonealarm and firefox).
has anybody ever heard of this sort of thing happening with a new CPU (the BIOS thing and the program crashes) ? everything worked flawlessly on the old 2.4 and everything was up-to-date (drivers, BIOS version, windows updates). i'm completely baffled as to how this one new component is causing all this trouble.
here are the system specs if it helps:
3.2 prescott - watercooled, stayed around 135f all day
1gb corsair xms pc3200 (2x512)
dfi lanparty 865pe 'B'
x800 pro
audigy 2 zs
2 raptors (raid 0) + 1 storage drive
52x cd burner, 16x dl dvd burner
enermax 350w psu <- could this not be enough power anymore w/ new CPU?? could that cause the kind of problems i'm having??
well, thank you for your patience for reading all of this and thanks in advance for any help.
x800 pro
audigy 2 zs
