Upgrade
klaatu51
I am running BOINC version 5.4.9 and noticed that there is a newer version. If I download the newer version will it automatically replace the older version, or will I have to remove the current version and then download the newer version?
Will it attach to the same project?
Any thoughts would be appreciated.:confused:
klaatu51
The download should automatically replace the orginail version on your machine. As long as the installation paths are kept at default.
I
It will just ask if it's ok to overwrite existing files........allow and you're good to go :)
Thanks folks. Everything seems to be working, but it didn't ask about overwriting any files. I appreciate all the help.
klaatu51
My bad..........getting senile, I may have confused it with MJ12 update.
(note to self........too many projects).
Apologies........anyway, glad your sorted :)
