Upgrade time?
SLiGuy
Hey all. I think it might be time to upgrade my PC soon, I wanted to know what you guys think. As customary, here's that form :p
Mostly gaming, primarily BF3.
$300-500. With taxes/shipping would be nice, but I can go a little bit over.
San Jose, CA (Fry's + Microcenter accessible)
CPU? RAM? Video card? See elaboration below.
6) Will you be overclocking?
No.
7) 7) What is the max resolution of your monitor? What size is it?
Planning to use 1900x1080
A month, give or take.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
N/A
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes
So here's the deal. I built my current PC (specs in sig) in August 2010. It's held up pretty well but its also beginning to show signs of age, especially in BF3. I'm currently only playing at 1440x900 right now and I can handle everything on high no problem. I haven't cranked it up to ultra yet but I expect that I'll receive a significant loss in framerates. I'm also planning to upgrade my monitor soon (not included in the $300-500 budget), somewhere between 21" - 24", which means naturally the resolution will be 1900x1080.
I don't want to do a completely new build just yet as I think I can squeeze a few more years of good gaming out of this rig (feel free to disagree). I'm not sure what my biggest upgrade would be, though. I would imagine that my video card is probably my biggest bottleneck right now. With the new 7xxx cards coming out soon and prices for old tech probably dropping, is a new video card the way to go? How about my CPU? I know it's dated tech right now, but can it still give me a few more years or is it going to hold me back as well if I get a new GPU? RAM-wise, would upgrading to 8GB yield any performance increases? I might considering doing that especially since RAM is dirt cheap right now.
What do you guys think? What do I upgrade first and what do I upgrade to? Or, given my budget of $500 and the potential to make another several hundred dollars from selling my current stuff, would it be better to go with an entirely new build?
Are you willing to OC your current CPU to 3.6Ghz or higher? That'll extend the life of your current setup a bit. In this Swedish BF3 Multiplayer review, the 3.7Ghz Phenom II X4 980 provided a respectible 54FPS and 68FPS at Ultra and medium settings respectively on Caspian Border at 1920x1080:
http://www.sweclockers.com/artikel/14650-prestandaanalys-battlefield-3/5#pagehead
Read the above review, decide if you're willing to OC or not, and tell us if the CPU performance increase from going to a Phenom II X4 980 (basically your current Phenom II x4 945 OC'd to 3.7Ghz) to a Core i5 2500K is worth the ~$360 upgrade costs (CPU, mobo, and new RAM included) to you.
RAM wise, RAM is dirt cheap at this point in time. If you're the type to leave a ton of apps running in the background, go for 8GB of RAM.
I'd be willing to OC. I'll do a little more research about my particular board first though. 3.7Ghz is a fair bit higher than stock speeds and my board is an mATX so I'm not sure about how capable its chipset is as far as OC'ing goes, but if I can I definitely will.
How about a new GPU? I'm almost certain that upping the resolution from 1440x900 -> 1900x1080 will cripple my video card on high/ultra. What's a capable card of running that resolution smoothly? Is there a single-GPU solution that can run it well or am I looking at XFire/SLi here?
You are correct. Go for the AMD HD 6950 2GB or Nvidia GTX 560 TI 448 Core. Those cards are more than enough for 1920x1080 at high.
