Upgrade time! CPU/Mobo - $400-$500
KatalDT
Gaming, photoshop, web browsing, work (including VMs and stuff).
$400-$500, yes. (NY, so Newegg = no tax, Amazon = tax)
New York
CPU, Motherboard - maybe a cooler included in this budget
2x GTX 460 1GBs (SLI), 4x4GB G.Skill Ripjaws, Corsair 750TX, Cooler Master Cosmos 1000, Hard Drives (4x WD Black 640)
6) Will you be overclocking?
...Maybe. I currently have a Cooler Master Hyper 212 Plus
27" 1920x1200 (for gaming), have 2x 22" 1920x1080 on the sides for desktop use.
Soon.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
SLI, onboard audio.
Windows 7 64.
I don't need a crazy motherboard. Just needs to support SLI and 4x DDR3. Was really interested in BD but it's kind of a disappointment, so I'll probably head towards the Intel processors. :( I do live near enough to a Microcenter, so I can cash in on their CPU/Mobo deals when they come up.
Ok, grab the Core i7 2600K and the Asus P8Z68-V Intel Z68 Motherboard for $380 from Microcenter. When you buy a motherboard with the Core i7 2600K at MC, they knock off $80 off the motherboard. So the $180 Asus P8Z68-V would be $100. $100 for one of thoe most solid mobos out there is damn good. Ad here:
http://viewer.zmags.com/publication/17ffca68#/17ffca68/27
Is the stock cooler adequate for some overclocking? Not looking to set any records, but a boost wouldn't hurt. Don't care if it's loud, my computers are in the other room and I run all the wires through the wall so I don't hear them.
Some very limited overclocking probably. Though if you already have the Hyper 212+, might as well use it.
The Hyper 212+ run decently on the 2600k? If not, I'd be fine with dropping a bit more on a decent air cooler. Loud is 100% fine.
Thanks. :D
Use the Hyper 212+
For what its worth, I am running a i5 2500k @ 4.2 Ghz with the stock cooler. Temps never go above 50C
Awesome.
I might need to grab a mounting bracket... right now it's on an 1156, and the 1155 has a different mounting bracket unless I'm mistaken.
Same exact mounting bracket as LGA 1156.
Anybody know if I'll be needing to upgrade any time soon for GTX 460 1GB SLI's? Single screen 1920x1200. Most intense game I'll be playing soon *maybe* is BF3, and only if it doesn't require Origin... call me paranoid. :)
I just finished a build with what Danni recommended the Asus P8Z68-V PRO and a 2600k.
I also got the H100 Water cooler on it.
4.7GHZ Intel Burn text Extreme continuous stable.
The twin 460's should be fine for your listed purposes.
Dunno about GTX 460 1GB SLI with BF3 since BF3 isn't out yet ;)
And looks like you won't be playing BF3 anytime soon since the PC version requires Origin to play.
