Hey guys, first real post
Here are my current specs:
Phenom X4 9550 @ stock 2.2ghz
6GB of DDR2 800 RAM
8800GT @ 750/1750/975
Corsair 450VX PSU
Windows 7 Home Premium x64
Now, I believe my processor is still adequate, even though the clock speed is pretty low.
I have 2 different options in upgrading so here they are:
1.)
2.)
Option 1 seems fairly good, but if my processor is adequate, I'll definitely go with #2.
If I go with number 2, should I just get the 5770, try to find a 5850, or get a GTX275/4890 (they are basically the same in performance, right?)
*EDIT* I play [or try to play] all of my games at 1920x1080 with some AA (usually 2x-8x) with 16xAF. The 8800 can't really do that well with AA, so I've been leaving it off in newer games like MW2 and Borderlands. I suppose this info would be important in deciding which card to get.
Thanks guys!
6GB of DDR2 800 RAM
Corsair 450VX PSU
1.)
- Replace the X4 9550 with a Phenom II X4 955
- Replace 8800GT with a Radeon 5770
- Keep the 450VX
2.)
- Replace 8800GT with a GTX275 -or- Radeon 4890
- Replace 450VX with the 550VX for the 41 amps on the +12v rail
Thanks guys!
