Sparkynutz
- Jul 31, 2007
I am looking to upgrade my video card if it will be beneficial.
I only play warcraft 3 and now starcraft 2
no other games and dont really plan on it.
I dont really care if I need my settings turned down as long as my screen doesnt get laggy. I want to spend as little as possible on a new card and only if it is needed.
I'll probably be building a new computer in a year or two and want to hold off upgrading this one if I dont have to.
my current setup is
q6600 on an abit p35 mobo
corsair hx520 power supply
2gigs ddr2
ecs 8800gts video card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814134037
19" acer cheapo lcd monitor
I've had this rig for a little over 3 years now and will be buying a new hdtv to use as a monitor.
Im moving my computer into the kitchen and would like to watch tv on it.
it seems to play starcraft2 fine now on all the highest settings but I havent played it much yet and my screen resolution on the 19" acer isnt as high as it will be with a new 22-27"
I'm leaning towards getting this acer-
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009268
in a week or two once my kitchen remodel is complete.
Im thinking of getting a dvi to hdmi adapter and trying it out first.
the new hdtv's im looking at dont have dvi inputs and my video card doesnt have a hdmi output
What do you guys recommend or just try the adapter and see how it goes?
thanks,
Ryan
my current setup is
2gigs ddr2
thanks,
Ryan
