upgrade question
jonneymendoza
Hi im oplanning on mving into the pci express phase after i have been with agp for so long and i was wondering when is the next different kind of slot for the cpu and gfx card comming out? in other word how long is pci express going to last>? i dont wanna buy pci express next year and a couple of months later a new type of thin comes out!
PCI express will be out for a while. In fact, PCI express v. 2 should be out soon with the P35/X38 boards with more power to the slot and double the bandwidth. But the cards you buy today will work with future slots for the forseeable future.
ahh ok so its wise to get ddr3 with p65 board? how much watts on a psu would i need to run a 8800gtx , 4 sata hdd's, 2 dvd drives and a quad core cpu? will 600w do?
Well the new PCI 2.0 might be a dud like AGP pro was... if I was you I would go for P35 with DDR2 ram and if you can go or want to be futureproof go straight 4 gigs which is still cheaper then 2 gig of DDR2.... if you do that go 64 bit operating system ofcourse...
The performance benefit at the moment of DDR3 over DDR2 isn't worth the cash....
Concerning the PSU 600 watt is plenty but make sure it has enough amperage at the 12 volt rails... eg split rails 20 amps at the 12 volt rail, single rail PSU make sure it's over 24 amps at 12 volt...
