Please view my system specs in signature.
I have $200-$300 budget so I can only to upgrade one major component. Where can I do the most damage? I am either going to buy a new video card or a new processor (and motherboard possibly). If a new video card I wouldn't mind having near top of the line but not the outrageous price they charge when something is first released. Something that has come down in price after a few months preferably.
If a new processor and mobo would be better, which combination would be a good one for the price range? I don't mind having either Intel or AMD, whichever would net me the best performance for the price range (and I definitely will want to be able to keep my current RAM).
My machine is used primarily for gaming. I record using FRAPS and that tends to lower my FPS a bit. I also encode videos for youtube frequently so I wouldn't mind that being a little bit more efficient as well.
Thanks in advance for the help! It is appreciated.
EDIT: It might also be helpful to know that I use a ZALMAN CNPS9700 CPU cooler, which came highly recommended at the time I put the PC together. Haven't had any cooling problems since but I don't overclock or anything like that.
