Web/Office/Database/Adobe CS/Pro Tools/Game/Movies
Somewhere around $500. If something cool like Eyefinity wasn't much more I could stretch it.
3) Where do you live?
I have Microcenter, Fry's and Tiger Direct nearby.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
CPU/MB/RAM/GPU
CM 690
OCZ GameXStream OCZGXS700
WD6400AAKS
WD15EARS
NEC ND-3550A x 2
M-Audio 2496
Peripherals
6) Will you be overclocking?
If required to get the performance I need
Dell 2007FP - 20" 1600 x 1200
Dell 2004FP - 20" 1600 x 1200
In time for the brutal Chicago winter, the next month or so, possibly early December
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Don't absolutely need anything but I like high quality
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
Windows 7 64bit
This PC is a hybrid mixed function of old/new parts. I'd like to keep it a hybrid for work and hobbies like gaming, music, and possibly video editing later on. I don't need bleeding edge but don't want to have to buy twice because I bought cheap. I guess I'm look at AMD parts with that budget (which like I mentioned could be increased if I was going to miss out on something great).
CPU/MB/RAM/GPU
CM 690
WD6400AAKS
WD15EARS
NEC ND-3550A x 2
M-Audio 2496
Peripherals
Windows 7 64bit
