depending on what you're willing to spend I concur with the previous post; the gs should be around 200, and it'll perform around a 6800gt. the 7800gt will be more expensive, but then again faster.
For less than $200, you can get the Connect3D X800GTO for $150 after rebate from newegg. Success rate has been close to 100% at unlocking all the pipes.
