Upgrade for q8200
EricFX1984
I know we have a lot of choices here
I was thinking an i3 maybe?
It will be used in an HTPC that also plays WoW and might play Starcraft II
Here, help yourself out.
If you're gonna ask us to build/list a PC for you or seek advice about a build, please answer all of the following questions:
3) Where do you live?
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
6) Will you be overclocking?
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
By answering these questions you help us help you build a PC that's of better quality, better performing, cheaper or all of the above.
1.) I think I already answered that
2.) max $200
3.) kansas city area, near a microcenter
4.) just a CPU, maybe a cooler
5.) motherboard, ram, etc, everything but the CPU, I already have a few motherboard sitting around... I have an MSI 890GXM-G65 (AM3) and a Gigabyte p55m-ud4 (1156)
6.) I have never had a machine that I didn't overclcok
7.) this question does not apply, I am not doing a full build just upgrading a slow CPU
8.) in the next 2 or 3 weeks at the most
9.) this question does not apply I already have a motherboard (2 actually)
10.) I will be using the one currently installed on the machine
q8200 is not a bad cpu. an i3 IMO would be a downgrade. You should be able to get the q8200 to 3.3 or 3.5 fairly easily. If you are having problems overclocking it then I would ask for help on that, but overall I think it is a better solution than your "upgrade" unless you are trying to solve other unstated problems.
Actually, the Q8200 is not that good of a CPU, despite what you stated. This is because it has too little L2 cache (only 1MB per physical core), and it has a very low multiplier (7x) that makes it rather tough to do much if any overclocking. You'll find that you'll run completely out of on-motherboard memory controller headroom at fairly low overclocks.
The i3 would not have been enough of an improvement over the Q8200 to be worth paying its lowest street price for. On one hand, it has an in-CPU-package (but off-die) memory controller - while on the other hand it has only two physical cores. Plus, the i3 has no TurboBoost feature that would have boosted the performance in single-threaded apps.
however if I put an i5 750 in there it would likely out do the Phenom II 965 I have in my other rig...
And the problem being?
As stated earlier, the Core i3 line won't be that much of an improvement to justify the cost. In addition, the Core i5 6xx series CPUs are insanely overpriced for being dual-core CPUs. So the logical and best bang for buck choice would be the Core i5 750 or 760.
However, it appears that you want to maintain your other rig's superiority for some reason and since you do have an AMD motherboard already, check out the Phenom II 945. It's not fast enough nor does it OC that high enough to threaten your other rig's sovereignty over the other PCs but still significantly faster than the Q8200.
