First of all, let me say I'm on a budget of $580, and I already have a mouse, keyboard, monitor, PSU, etc. All the stuff posted here is all I need.
Case: LIAN LI PC-7B plus II Black Aluminum ATX Mid Tower Computer Case - $79.99 <http://www.newegg.com/Product/Product.aspx?Item=N82E16811112099> I chose this because the case has a good cooling and aluminum design, along with smooth edges.
Motherboard: ASUS M2N-SLI Deluxe AM2 NVIDIA nForce 570 SLI MCP ATX AMD Motherboard - 124.99 <http://www.newegg.com/Product/Product.aspx?Item=N82E16813131013> A friend recommended this to me, and from what I see on the forum it's good enough. I also chose AMD due to my budget.
Video Card: SAPPHIRE 100176L Radeon X1950PRO 256MB 256-bit GDDR3 PCI Express x16 HDCP Ready CrossFire - 134.99 <http://www.newegg.com/Product/Product.aspx?Item=N82E16814102061> I was going to go with a 8600gt at first, but after looking on the forums, this card supposedly blows that one out of the water, and costing only about $5 more.
Processor: AMD Athlon 64 X2 5200+ Windsor 2.6GHz Socket AM2 Processor Model ADA5200CSBOX - 119.00 <http://www.newegg.com/Product/Product.aspx?Item=N82E16819103759> I chose this nearly for the same reason I chose the mobo.
RAM: G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-2GBNQ - 49.99 <http://www.newegg.com/Product/Product.aspx?item=N82E16820231098> I saw this deal on the forums when I was looking up my first choice which was a Corsair 2gb (2 x 1gb) that costed twice the price.
Subtotal: $508.96
I would like some feedback to see if there's possibly any better deals out there.
Subtotal: $508.96
