Upgrade Decisions - AMD vs Intel Choices
mt_100
I want to upgrade from my current system which runs great but is getting a little slow on games. As part of the upgrade I want to save my Antec Aria case and my Sapphire Radeon X1900GT PCI-E card because both are fine in my opinion.
Choices are the AMD path or the Intel path, help me decide. The AMD option draws less power according to the Extreme PSU calculator and lets me save a bit of cash. Although I don't plan on overclocking the possibility is nice. I know the Intel will overclock well but not sure on the AMD.
Common Parts for Both
A-DATA 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 http://www.newegg.com/product/product.asp?item=N82E16820211066
Seagate Barracuda 7200.10 250GB 7200 RPM 8MB SATA 3.0Gb/s http://www.newegg.com/product/product.asp?item=N82E16822148261
AMD Choices - $270 total
AMD Athlon 64 X2 4000+ Brisbane http://www.newegg.com/product/product.asp?item=N82E16819103774
ASUS M2A-VM http://www.newegg.com/product/product.asp?item=N82E16813131174
Intel Choices - $312 total
Intel Dual-Core E2160 Allendale http://www.newegg.com/product/product.asp?item=N82E16819116036
GIGABYTE GA-G33M-S2 http://www.newegg.com/product/product.asp?item=N82E16813128060
Keep in mind I don't have a huge budget however small ideas for changes are welcome. So what are your thoughts?
If you're not overclocking, then I'd go with the AMD build since the X2 4000+'s performance is the same as the E2160. However C2Ds are really easy to OC and with very very few problems. Even with a minor OC, the E2160 will outperform the X2 4000+ by a large margin:
http://anandtech.com/cpuchipsets/showdoc.aspx?i=3112&p=14
But if you don't want to OC, for the AMD build, I'd go for this mobo instead since it has an HDMI port built onto the mobo and it has gotten a few good reviews:
Gigabyte GA-MA69GM-S2H AMD 690G mATX Motherboard - $80
The Asus has HDMI and good reviews as well and is cheaper. I know the Intel will overclock well since there is an article on Tom's Hardware regarding that chip being overclocked by a large margin. Having never build with Intel I have no idea.
I know either config will blow my current one away (Sempron 3300+ with 2GB DDR400) so performance is going to be good. I just wonder if the Intel config is worth the $42 more in the long run.
i went with amd due to there costs.have been with amd throught thick and thin.the intel is the better core and these things are darn fast.got my 6000+and it has more than enough power for me.i guess it is just how much you want to spend.search around for the best performance/cost ratio.cheers
Yeah, think I am going the AMD route. I've used them for years and like them as well as not having to OC for more speed.
If you were willing to spend more go e4300. But since you have what looks like a set price range go with the AMD Cause the 690g is a fantastic chipset. I'd go Gigabyte 690g personally If I had the extra cash I'd be using one for my new HTPC.
With your budget AMD is the better choice. I've always been a proponent of buy all the clock speed you can afford. If you were going to OC I would try to push you to the Intel but at stock speeds the AMD is the better choice.
If you get the an AMD 690 board can you post your thoughts on it I will be building a AMD based comp for my roommate in a couple months and I have been eying the Gigabyte 690G board for it. But there are all but no reviews out for boards with this chip set.
