Gobstopper
- May 15, 2008
This isn't necessarily a build thread, but I thought I'd answer some of the sticky questions for more complete info.
Web Browsing, Photoshop, Premiere, Skyrim
I am looking to play Skyrim on my PC that I will hook up to my TV instead of my monitor. TV is an LG 55" LED TV if that matters at all http://www.amazon.com/LG-INFINIA-55LE8500-Internet-Applications/dp/B0039RRBQC
My main concern here is the value of upgrading just the CPU and GPU instead of building a new computer. I'm not sure if upgrading to a CPU that fits my older socket would even be worth it, but I do not play that many PC games aside from Starcraft 2 and soon, Skyrim. I realize Skyrim isn't out yet and performance can't be determined; I'm going by Bethesda's recommended specifications at the moment. I'd like to go a bit over the specs in hopes of running the game on as high of settings as I can.
Skyrim Recommended Specs
CPU: Quad-Core Intel/AMD CPU
Memory: 4GB RAM, 6GB Hard Drive Space
Video Card: DirectX9 video card with 1GB memory. GTX 260/Radeon 4890 or higher
$350 w/ tax and shipping
Palo Alto, CA. 20 minutes from Microcenter.
4) What exact parts do you need for that budget?
CPU and GPU only. Keeping the rest of the parts on my current setup.
My current setup
Mobo: Asus P5Q Pro
CPU: Intel Core 2 Duo E8400
Cooler: Xigmatek HDT-S1283
GPU: EVGA GeForce GTX 260
RAM: G.Skill 4GB DDR2 1000 (PC2 8000)
Hard Drive: Western Digital Caviar 640GB
PSU: Corsair CMPSU-750TX 750W
OS: Windows 7 64bit
Case: Cooler Master CM690 (first model)
6) Will you be overclocking?
If practical, yes.
24" at 1920 x 1200. Will be using the TV mentioned above as the display when playing Skyrim though. The rest of the time, computer will use the Samsung 2493HM.
8) When do you plan on buying the parts?
This week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Not Applicable
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Will continue to use my current OS. Windows 7 64bit
My questions
1) Considering that I do not play that many PC games, would it be a good value to just upgrade my CPU and GPU instead of doing a complete build? If so, which combination would be best? My socket is pretty outdated so if I do decide on a new build in the future, I would need to buy another CPU, but the GPU I can reuse.
2) The GTX-260 has dvi out only and no hdmi out. I will need to use a dvi to hdmi converter to output to my TV. Does this mean that the sound would have to come from the computer instead of the TV?
3) The few times that I have seen a PC hooked up to an HDTV have resulted in blurry images. Is this to be expected or can this be remedied by settings or newer hardware? I wouldn't want to go through all this trouble and end up with a blurry image.
Well, thats about it. Thanks!
My current setup
Mobo: Asus P5Q Pro
OS: Windows 7 64bit
If practical, yes.
This week.
Not Applicable
My questions
