-- What your budget is (and whether it includes taxes, shipping charges, and/or other costs)
About $500-700
-- Which parts you need within that budget
Mobo, Processor, Ram, SSD, Maybe a power supply
-- What the system is going to be used for
Gaming, running a small home network for storage, office work
-- All of the components that you already have and/or are planning on reusing
Reusing: Lian Li PC-61 and I would like to reuse a XFX GeForce 9600GT just until I get enough money to upgrade that, a PSU (I may need to upgrade but Its pretty hefty), and 2 500gig SATA HD's
-- Which components you are considering getting (list out your components with model
numbers/names along with links to the stores you're getting them from)
ASUS P7P55D-E LX LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Model #
7P55D-E LX $124.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131634
Intel Core i7-870 Lynnfield 2.93GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor BX80605I7870 $289.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115213
Crucial RealSSD C300 CTFDDAC064MAG-1G1 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD) $144.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148357
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL $104.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
Once I have enough money I think I'll get this:
EVGA 01G-P3-1373-AR GeForce GTX 460 (Fermi) Superclocked EE 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130568
-- The question(s) you have -- or, the reason you made the thread in the first place
How does this build look?
-- Be as specific/detailed as possible (without writing a novel -- some of us have short attention spans here...)
Main concern is compatibility and value. I would like to upgrade by the end of the month, the reason why I'll get the graphics card later is because my computer has been freezing as of late and is also in need of an upgrade anyways.
Thanks in advance
About $500-700
Model #
Thanks in advance
