Upgrade build. Please comment.
Jellox
I already have a case, optical drives, hard drives, and power supply. I still need a motherboard, processor, memory, video card, and cpu cooling.
Here is what I have come up with so far:
https://secure.newegg.com/NewVersio...ishListNumber=4355534&WishListTitle=New+Build
I will be overclocking it as far as I can get it. I already have two WD2500 250gb Sata HDDs, and an OCZ 700w psu.
I am looking to get the most for my money and want to spend around $1100. Any comments? I'm mostly concerned on my choice for RAM/MOBO.
Thanks!
Thanks!
Do you really need 2 motherboards for that build? :p
For $190, wouldn't you rather have 4 gigs of memory? There are many sticks pf pc2-6400 memory that would gladly overclock to the levels you would hope to get out of your e6600. At 9 x 400, you would be at 3.6 ghz and at stock speed of the memory. Do you really need to have pc2 8500 memory?
A lot of people will tell you not to get the 9700 zalman, but I use one, and do like it better than my scythe ninja plus in my p4 2.8 rig.
1) it's easier to install
2) if i needed to uninstall it, it would be cake
3) it's prettier
4) though it might cool 2 or 3 Celsius worse than the tuniq 120 or other highly rated coolers, it's not a huge difference in overclocking results
5) it's a lot easier to find than the tuniq 120
rofl, an 80 $ price before rebate for the 9700 isnt worth it,i love my ninja, even though installation was a pain.
It's not a rebate, it's instant. $65 is the most i've seen it at egg these past few months. It was as low as $55 at one point.
installation of the ninja isn't any harder than the stock intel cooler; and for the price, the ninja is a great cooler. i agree, you don't need ddr2-1066 ram with an e6600. stick to some ddr2-800, like the g.skill 2gbnq kit instead.
I rememberd it being a pain... maybe the mountings were different for the socket 478. I did try to remove the heatsink last weak however, no luck. Is there an easy way to get it out?
Sorry, I havent used the s478 mounting bracket, only the lga775.
Socket 478 is a pain in the ass in general to install heatsinks on IMO.
Anyway, OP, Here are my motherboard recommendations:
EVGA 122-CK-NF66-T1 LGA 775 NVIDIA nForce 650i Ultra - $110
GIGABYTE GA-965P-DS3 Socket T (LGA 775) Intel P965 Express - $130
Either of these mobos will give you good overclocking results.
