Upgrade after 8 years
beef
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? etc All three
2) What's your budget? Are tax and shipping included? $1500 CDN before taxes. No shipping as I will shop local and pick up.
3) Where do you live? Metro Vancouver BC.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need. CPU, Ram, PS (modular),Vid Card, HD, MOBO
5) If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. List make and model. Nothing***
6) Will you be overclocking? Maybe
7) What size monitor do you have and/or plan to have? 23" Acer
8) When do you plan on building/buying the PC? As soon as B3 motherboards are avaliable (end of the month).
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc. USB 3, SATA 6
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit? No, will need to purchase Windows 7 pro
I had thought of the Asus P8P67 Deluxe mobo, i7-2600k unlocked, Corsair CMZ8GX3M2A1600C9 Vengeance 8GB, Sapphire 100314SR Radeon HD6870 1GB, and Corsair HX650W PS. Been out of touch for a while; a new family will do that to you. Any advice would be appreciated. Oh, I will make most of my purchases at A-power.com or N C I X.
[/COLOR]5) If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. List make and model. Only DVD burner and case.
That response is very questionable right off the bat:
First off, Is your DVD burner IDE or SATA? (Many newer motherboards have no IDE ports at all whatsoever.)
Second, how old is your case? (If that case is more than four to five years old, its airflow would likely be woefully inadequate for today's very-hot-running high-performance modern components and might very well be so cramped on the inside that even a mid-level GPU would have been a very tight squeeze inside that case.)
Sorry, I won't be re-using I already have those two items picked out; Lite-On IHAP322 PATA SuperAllwrite DVD Writer and Cooler Master CM 690 II Advanced case.
That DVD drive is still not usable on some of the newer motherboards: Many if not all of the Sandy Bridge motherboards have no PATA ports at all. And that's not to mention that Intel's chipsets lack native PATA support since the days of the Core 2 Duo and the P35 chipset.
In my first response, PATA = IDE.
My bad. I guess I should pay a little more attention. Embarrassing.
Yes. A SATA DVD burner is required for most of the newer motherboards.
A few notes about this build:
- Do note that even if you're planning on overclocking, still little to no reason to get DDR3 1600 RAM. You're gonna see the same real world performance with DDR3 1333 RAM. So you can definitely save some money and go with DDR3 1333 RAM
- That Sapphire HD 6870 1GB costs just as much as a XFX HD 6870 1GB card. So I recommend XFX over Sapphire due to the better customer service and longer warranty
- From what you've answered so far, you should be fine with the Asus P8P67 LE. I don't see a reason for the Deluxe mobo at all.
