upgrade advice on a e6300
jonneymendoza
Hi i am in the proccess of building a new pc for someone. One thats no too expensive whilst having room for future upgrades. I would like to overclock a bit as well. would these components be enough to overclock the hell out of a E6300?
specs
Mobo: Abit AB9 Pro i965
http://www.scan.co.uk/Products/Produ...oductID=433274
gtx: 256MB Sapphire Radeon X1600Pro
http://www.scan.co.uk/Products/Produ...oductID=462640
Memory: 1GB CorsairXMS2
http://www.scan.co.uk/Products/Produ...oductID=239017
Cooler for cpu: Arctic Cooling Freezer 7 Pro
http://www.scan.co.uk/Products/Produ...oductID=340995
dvd drive: LiteOn 16x DVD+/-RW/RAM SATA beige
http://www.scan.co.uk/Products/Produ...oductID=520882
PSU:460W Akasa Ultra quiet aPFC
http://www.scan.co.uk/Products/Produ...oductID=154679
Case: Thermaltake Soprano SECC Silver, Window
http://www.dabs.com/ProductView.aspx...80&InMerc h=1
Read the [H] reviews on the recent abit conroe boards. They're not highly recommended.
Definitely try to go with a Gigabyte DS3 or an Asus P5B-E board instead.
For people that live in the U.S. you might want to go with something like an X1900GT like this one for only $164.99 at the Egg.
http://www.newegg.com/Product/Product.asp?Item=N82E16814102022
It would give you a nice boost in gaming performance for very little extra money.
I like the 1900GT as well, suggest you go with E6400 as the higher multiplier will let you overclock higher (lower FSB speeds) without stressing your ram or motherboard as much. Only a few pounds/euros/bucks more and will make overclocking so much easier.
