1) What will you be doing with this PC? Gaming
2) What's your budget? $500-$600 pre tax
3) Which country do you live in? TN, USA
4) What exact parts do you need for that budget? Unsure (explained below)
5) If reusing any parts, what parts will you be reusing? Unsure (explained below)
6) Will you be overclocking? No
7) What is the max resolution of your monitor? What size is it? Acer 24" 1920 x 1080
8) When do you plan on building/buying the PC? Hopefully within a week or so
9) What features do you need in a motherboard? No specific features. I don't plan to SLI or overclock. I'm just looking for a decent mobo that will utilize my hardware.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Windows 7 64-bit
Hello,
I plan to upgrade my system (current specs below) and I was hoping to get some advice.
I'm on a budget of about $500-$600 so I need to choose my upgrades wisely. I generally use my system for gaming and don't really get into overclocking. I feel like the weak areas of my system are the graphics card and the HDD, so I think that's what I will focus on first. Do you guys agree?
I'm leaning toward the 660Ti and SAMSUNG 840
Also, I'm having a little trouble figuring out what to upgrade next...CPU, Mobo, PSU? I'm definitely not as up-to-date on hardware as others, but I feel like I would be fine using my existing CPU, Mobo, and PSU with the new video card and SDD I mentioned above.
All advice is much appreciated.
---Specs---
COOLER MASTER Hyper 120mm CPU Cooler
ASUS 24X DVD Burner
EVGA GeForce GTX 560 Ti
G.SKILL Ripjaws Series 8GB
Intel Core i5-2400 Sandy Bridge 3.1GHz (3.4GHz Turbo Boost) LGA 1155 95W Quad-Core
ASUS P8Z68
CORSAIR HX series HX650 650W
Antec Nine Hundred Two
Seagate Barracuda ST500DM002 500GB
Hello,
---Specs---
ASUS 24X DVD Burner
ASUS P8Z68
