Vinsanity74
- Apr 29, 2012
I can't decide which upgrade route to go. I currently have an MSI X-58M running an i7-920, with an HD5870 video card. I am either going to upgrade the mb/cpu to an IB or SB board and chip....or I'm going to replace the video card with a GTX680.
Which would benefit me most? Pretty much just a gaming system.
Thanks!
1) What will you be doing with this PC? Gaming + Web
2) What's your budget? $500 or so
3) Which country do you live in? Ohio, USA
4) What exact parts do you need for that budget? CPU + MB, or Video Card
5) If reusing any parts, what parts will you be reusing? Corsair 750w PSU, OCZ1600 - 2GB x 3
6) Will you be overclocking? Moderately
7) What is the max resolution of your monitor? 1920x1080
8) When do you plan on building/buying the PC? Next couple of weeks
9) What features do you need in a motherboard? RAID (running 2 SSD's in Raid-0)
10) Do you already have a legit and reusable/transferable OS key/license? Windows 7 64-bit.
Thanks!
