Hi all,
It's been quite awhile since I've needed the advice of the brain trust but here I am.
I'm due for a system overhaul. The system I bought was way back in 2008 and its been great so far. But since then I've noticed it becoming somewhat sluggish so the questions I put to you:
I definitely need to upgrade my GFX card. But what would the preferable option be here? Wait till spring for the new breed to be unleashed or go with a top gunner now?
I need more RAM. I want to go up to 24GB since that's the most my current MB will allow me. Should I add to the current setup or get rid of them and buy a whole new set? recall these Mems were bought back in 2008. I prefer to stick to 1600 MHZ range.
CPU. This one is a bit trickier. I dont feel like I need to change this one since it's a beast by its own right. But I defer judgment to you wise few who've been following the trends way more thoroughly than I have.
Anything else I would have missed?
Ah, my computer needs are as follows: Digital art, I'm a concept artist and a 3D modeler and I do play games, mostly the Total War series.
Budget: Not an issue.
Thanks lads!!
Thanks lads!!
