Updating BIOS but system won't boot.
zsec
Biostar has a BIOS update so you can stick a AMD Deneb in their AM2+ mobos, but can you update the mobo's BIOS if the system will not boot?
Is booting the same as posting? Because if it posts, you can flash a new BIOS, correct?
Notes :
If you plan to use the latest AMD's AM3 processor, there is a chance the system may fail to boot for existing motherboards in the market. Please update bios with existing compatible AM2/AM2+ CPU if you encounter this situation. If bios is already updated to support AM3 processors, then no bios update will be necessary.
