Updates to phone.
Discussion in 'Smart Phones and Devices' started by OldBuzzard, Apr 15, 2018.
  1. OldBuzzard
    OldBuzzard Gawd
    698
    Jun 6, 2004
    OK, I'm fairly new to this whole smart phone thing.
    I was happy with my old dumb ass phone, and only changed because it died, and I had no choice.
    I use Tracfone as I don't really use a cell phone that much anyway, and it's the most economical service for me.
    Anyway, I purchased a Samsung Galaxy Sky (S320VL) through Tracfone, which I think is based on the Galaxy 8 and came with Android 6.0.1.
    In any event, I'm constantly being bombarded by 'updates' for Google, email, etc, etc.
    Is this normal?
  2. Krixon
    Krixon Limp Gawd
    334
    Mar 21, 2015
    If what you are speaking of are app updates, which show up as a notification from Google Play, then yes, it is quite normal. In an average week I'll get between 10-20 app updates. You can, of course, disable automatic updates, but I wouldn't recommend it as these are often upgrades to security and stability.
    OldBuzzard and auntjemima like this.
  3. auntjemima
    auntjemima 2[H]4U
    3,133
    Mar 1, 2014
    I second this motion. Call for adjournment.
    OldBuzzard likes this.
  4. OldBuzzard
    OldBuzzard Gawd
    698
    Jun 6, 2004
    OK, thanks for the prompt replies and information.
  5. T4rd
    T4rd [H]ardForum Junkie
    15,625
    Apr 8, 2009
    You can also just hold in on the notification to block future notifications from the Play Store for app updates or whatever else. The apps will continue to be updated, but you won't get a notification for it anymore. At least I think that feature was in 6.x.
    DF-1 likes this.
