I have been trying to find out if the new dual core chips are going to work with todays mobo's. I know that AMD is sticking with the socket 939. But will the chipsets and BIOS support the dual cores. I haven't read a ton of reviews on the dual cores but so far I haven't seen a diffinative answer yet. It seems from what I have read the answer will be yes but still unsure. I know that to do the upgrade you'll need the S 939. But the question is will the chipsets and BIOS support the dual cores. Does anybody know of any reviews I can read to get the answer?
