wayout2day
- Oct 15, 2006
Dell Dimension 3000 running Win XP HE. It took about 20 hours to load Windows. (Yes, I just let it keep going) Everything runs slow. Reformatted the HDD before all of this. But even programming in memory runs slow.
I have worked on a couple hundred PC's, first time for everything, I guess.
I put in tested RAM--no change.
I suspected a slow CD drive, but everything else still slow.
Ran Dell diagnostics. No problem with memory.
Tested the Power Supply. All numbers within good range.
Customer came in with PC Loaded with fur, hair and dirt. Everything was clogged. Vacuumed the PC before pulling the HDD and reformatting. So I am suspecting a damaged Pentium IV 2.8 CPU.
Before I pull that and change it, are there any further tests I can run ??
