I just grabbed a 250GB IDE 7200.8 off TigerDirect against my better judgement. Anxious to get the thing working, I put it into the external enclosure I have at work. It didn't install properly, and win2k never recognized it. I saw it installing the drive, but then windows gave me an error message about hardware not functioning properly or something, and the drive was never mounted. I put my WD160JB back into the enclosure, and everything is normal.
Took the Seagate home and put it into its intended home: my file server. I had issues there even getting the pc to boot with the drive installed....but those could be caused by other things (don't I just love PC's!)
Took the drive upstairs to my main PC, plugged it in and started windows. XP saw the drive, seemed to install it, but nothing happened. Device mgr says the drive is fine, but XP sees no drive. I switched IDE cables, switched jumper settings, but no avail.
I'm not missing something stupid here am I?
Anyway, I only got this drive 2 days ago....should I return it to TD or try to RMA to Seagate? I need to get a MIR in the mail, so I would probably prefer to RMA so that I can send the UPC out.
