UNraid with b250 mining expert?
mnewxcv
I was thinking and wondering if it is possible to use UNraid with the b250 mining expert to effectively run 2 windows installs and therefore 16 nvidia cards without needing amd or p106 cards. Thoughts?
what are you asking here? Are you thinking virtualization layer or something? just dont.
i have done 5 dual gpu cards on esxi. (10 chips total) it worked well once i set it up. unraid is trash and i dought it would work. idk about that mobo though. make sure you can support vd-t properly. if you have the time i would give it a try on esxi or xen
