I bought a few GTX460s for folding and I'd like to watercool them but they are not reference so a full block is not an option. Originally I was going to go for the EK VGA Universal blocks but the price is a bit much for what you are getting so I found the XSPC RASA Universal GPU block. It fits a ton of different ones so I can use it for future cards if I need to.
So I ask, has anyone used this one or can provide a recommendation of a different universal GPU block? I will have 4 GPUs in the case so I figured I would just have to loop the tubing up and over to the next card. Probably going to use 3/8" so I can get a tighter bend in.
Thanks for the help!
