XBarbarian
- Dec 29, 2006
Tried to find the right spot to post this...but..eh
anyways...simple question.
I adjusted speedfan with the +15 to accommodate its issue with quads.
speedfan shows my qx6700 @ stock, auto settings, Zalman 6700 as this
CPU = 40
core0 = 49
core1 = 48
core2 = 44
core3 = 44
is the CPU the main temp to watch..or focus on the cores individually more?
40 seems damn high for idle at stock speeds and volts, but I guess the qx6700's run hot, but damn, I even lapped both cpu and HS today. Does it take days for the as5 to kick in?
I tried a minor oc by just upping the multi to x12 from the stock x10, which brought the CPU temp to 49 at idle.
the cores were in the low 50's.
is the CPU the main index to watch? are those temps what others are seeing?
maybe a new HS?
CPU = 40
core0 = 49
core1 = 48
core2 = 44
core3 = 44
maybe a new HS?
