I have been out of the loop for a couple years since my last build. I am getting the bug to build another system to replace E8400 CPU based system I now have. Here are the particulars of my present rig. I would prefer to stay with Intel CPU's
PC P&C 750 watt Silencer PSU : Gigabyte GA-EP45-UD3P Mobo : Intel E8400 Core Duo 3.0 GHZ : Corsair XMS TWIN2X4096-8500C5: Sapphire HD4850 GPU 512Meg : LG 22x SATA DVD-RAM burner : WD 640gig Black HDD : 2 x WD 120Gb IDE HDD : 3.5" IDE Floppy drive : Antec Performance Plus 1080 Case : 3-80mm Antec case fans
Here are my needs:
General usage. A little video editing not much. Surfing and general office programs. Downloading from the internet. Would like to have the capability of playing games on occasion but not at the highest level. I do some photo editing but not intensely.
I would like to stay under $1000 after rebates preferably lower including tax and shipping.
3) Where do you live?
USA , Chicago area
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
I need everything but the monitor. I have a HP2207 monitor. Would like an i7-920 based system if doable. For the case I was thinking Antec 900 or COOLER MASTER HAF 922 RC-922M-KKN1-GP ($60 after rebate for both cases at Newegg)
PC P&C 750 watt Silencer PSU possibly for new build and then swap that out for a cheaper PSU for my present system which is overpowered.
6) Will you be overclocking?
Yes some but not extreme
22" -1680x1050...Do not plan on going larger than 24 inch.
Now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
I do not need RAID or Crossfire. Firewire and onboard audio and ethernet are all I need.
10) Do you already have a legit and reusable/transferable OS key/license?
I need a new OS for a new computer. 64bit most likely Windows 7
I would prefer to stay Intel based but what I am really looking for is a substantial increase in performance over my present system. If I can do that with AMD then so be it.
Any help will be appreciated I have been out of the loop too long to make objective decisions on present day hardware even though I have done lots of research.
Here are my needs:
USA , Chicago area
Now
