Gaming only. Intend on using my 50" TV at 1920x1080. So I want something that will play all, and hopefully the near future, games at high frame rates at that resolution.
$1,000ish
Toledo, Ohio - little over 2 hours away from a microcenter
Case, MB, Processor, RAM, DVD Burner, Power Supply, Graphics Card (I'd like to get into 3d gaming possibly, my tv is 3D), HD, SSD as well if it fits in the budget and the benefits are as advertised, Windows 8 as well. Keyboard & Mouse unless it sacrifices too much $$$. (I have an old keyboard and mouse, nothing fancy)
None other than possibly keyboard & mouse.
6) Will you be overclocking?
Hopefully not for a couple years, but will in the future if newer games start to suffer.
1920x1080. 50"
Have the cash now, open to suggestion if I need to wait for a few weeks if something is coming out soon that you suggest I get or if it'd drop the prices of current hardware.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Leaving this up to you folks, I'm assuming SLI Support for future upgrade to graphics power would be smart.
Time to upgrade from Vista, I'd like Windows 8.
$1,000ish
1920x1080. 50"
