- Apr 27, 2006
Yea remastered definitely felt easier with the 60fps. I've played through all 3 on ps3 as well, and ps3 was definitely tough. Only played them on normal difficulty on ps3 I believe. The PS4 controller is a lot better. Also seemed to be some pretty heavy aim assistance that I'm not sure was configurable in the remastered ones? It tracked the target once you got your xhair on them, and often seemed your shot was lined up already when you popped out of cover.ammo is definitely an issue as you always need to be looting enemies to pick up more...unless you happen to pick up the China Lake grenade launcher which is pretty powerful...I use melee a lot in the game because of the limited ammo...for some reason the aiming doesn't feel the same as the previous Uncharted games...I only played the remastered Nathan Drake Collection versions so maybe the 60fps made the difference...here the aiming doesn't feel as precise and maybe it has to do with the 30fps
Still a lot of fun, but just stupid we can't use a mouse if desired, in SP at least. Combat would be so much more fun. Although 30fps with a mouse probably isn't much better.
